Arc object
Class AcadArc
Member of BricscadDb
The Arc object represents a segment of a circle or ellipse. To create an arc, use either the AddArc method. To access the Arc object, use the following methods and properties.
Methods Properties
ArrayPolar Application
ArrayRectangular ArcLength
Copy Area
Delete Center
GetBoundingBox Document
GetExtensionDictionary EndAngle
GetXData EndPoint
Highlight Handle
IntersectWith HasExtensionDictionary
Mirror Hyperlinks
Mirror3D Linetype
Move LinetypeScale
Offset Lineweight
Rotate Material *
Rotate3D Normal
ScaleEntity ObjectID
SetXData ObjectName
TransformBy OwnerID
Update PlotStyleName
  Radius
  StartAngle
  StartPoint
  Thickness
  TotalAngle
  TrueColor
  Visible
