PViewport object
Class AcadPViewport
Member of BricscadDb
The PViewport object represents a window that displays all or part of a drawing's paper space. To access the PViewport object, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular ArcSmoothness
Copy Center
Delete Clipped
Display CustomScale
GetBoundingBox Direction
GetExtensionDictionary DisplayLocked
GetGridSpacing Document
GetSnapSpacing GridOn
GetXData Handle
Highlight  HasExtensionDictionary
IntersectWith Height
Mirror Hyperlinks
  LabelBlockId
Mirror3D Layer
Move LensLength
Rotate Linetype
Rotate3D LinetypeScale
ScaleEntity Lineweight
SetGridSpacing Material
SetSnapSpacing ObjectID
SetXData ObjectName
SyncModelView OwnerID
TransformBy PlotStyleName
Update ShadePlot
  SheetView
  SnapBasePoint
  SnapOn
  SnapRotationAngle
  StandardScale
  Target
  TrueColor
  TwistAngle
  UCSIconAtOrigin
  UCSIconOn
  ViewportOn
  Visible
  VisualStyle
  Width
