Ray object
Class AcadRay
Member of BricscadDb
The Ray object is a line that starts at a designated point and runs infinitely. To create a Ray object, use the AddRay method. To access a ray, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular BasePoint
Copy DirectionVector
Delete Document
GetBoundingBox Handle
GetExtensionDictionary HasExtensionDictionary
GetXData Hyperlinks
Highlight Layer
IntersectWith Linetype
Mirror LinetypeScale
Mirror3D Lineweight
Move Material
Rotate ObjectID
Rotate3D ObjectName
ScaleEntity OwnerID
SetXData PlotStyleName
TransformBy SecondPoint
Update TrueColor
  Visible
