SelectionSet object
Class AcadSelectionSet
Member of BricscadApp
The SelectionSet object represents one or more drawing entities which can be operated on as a single unit. To access the SelectionSet object, use the following methods and properties:
Methods Properties
AddItems Application
Clear Count
Copy Name
Delete Visible
Erase
Highlight
Item
RemoveItems
Select
SelectAtPoint
SelectByPolygon
SelectOnScreen
Update
ScaleEntity
