Shape object
Class AcadPolyfaceMesh
Member of BricscadDb
To access the Shape object, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Document
Copy Handle
Delete HasExtensionDictionary
GetBoundingBox Height
GetExtensionDictionary Hyperlinks
GetXData InsertionPoint
Highlight Layer
IntersectWith Linetype
Mirror LinetypeScale
Mirror3D Lineweight
Move Material
Rotate Name
Rotate3D Normal
ScaleEntity ObjectID
SetXData ObjectName
TransformBy ObliqueAngle
Update OwnerID
  PlotStyleName
  Rotation
  ScaleFactor
  TrueColor
  Thickness
  Visible
