Solid object
Class AcadSolid
Member of BricscadDb
The Solid object is a solid-filled polygon. To create a Solid object, use the AddSolid or CreateSolid methods. To access a solid, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Coordinate
Copy Coordinates
Delete Document
GetBoundingBox Handle
GetExtensionDictionary HasExtensionDictionary
GetXData Hyperlinks
Highlight Layer
IntersectWith Linetype
Mirror LinetypeScale
Mirror3D Lineweight
Move Material
Rotate Normal
Rotate3D ObjectID
ScaleEntity ObjectName
SetXData OwnerID
TransformBy PlotStyleName
Update Thickness
  TrueColor
  Visible
