Trace object
Class AcadTrace
Member of BricscadDb
The Trace object is a 2D solid line of specified width. To create tolerance, use the AddTrace method. To modify or obtain information about a Trace object, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Coordinate
Copy Coordinates
Delete Document
GetBoundingBox Handle
GetExtensionDictionary HasExtensionDictionary
GetXData Hyperlinks
Highlight Layer
IntersectWith Linetype
Mirror LinetypeScale
Mirror3D Lineweight
Move Normal
Rotate ObjectID
Rotate3D ObjectName
ScaleEntity OwnerID
SetXData PlotStyleName
TransformBy Thickness
Update TrueColor
  Visible
