AddInMan
BricsCAD (Windows)
Brings up the VBA COM Add-In Manager.
command bar:  addinman
shortcut:  F11
alias:  Alias
menu bar:  Tools | VBA | Add-in Manager
: addinman
Change the load behavior of add-ins, and then click OK.
Available Add-Ins
Lists the names of VBA COM modules available to BricsCAD.
VBA COM is short for Visual Basic for Applications Common Object Model.
Load Behavior
Determines how modules are loaded:
  • Loaded/Unloaded toggles the module between loaded and unloaded.
  • Load on Startup loads modules at the same time as BricsCAD starts.
OK
Saves the changes, and then dismisses the dialog box.
Cancel
Undoes the changes, and then dismisses the dialog box.
AppLoad - selects external routines to load when BricsCAD starts.
Commands - lists the names of internal and external commands.
CuiLoad and CuiUnload - loads and unloads menu files.
Customize - customizes the user interface.
MenuLoad and MenuUnload - loads and unloads menu files.
Netload - loads a .NET application.
Security - depending on the selected security level (Low, Medium or High) VBA macros are allowed to run automatically or not.
VbaLoad and -VbaLoad - loads VBA projects.
VbaRun and -VbaRun - runs VBA macros.
VbaIde - opens the VBA integrated development environment.
VbaMan - manages VBA projects.
VbaUnload - unloads VBA projects.
