Draws a sphere as a 3D mesh surface.
command bar: ai_sphere
menu bar: Model | Meshes | Sphere
toolbar: Meshes |
: ai_sphere
Center of sphere: (Pick a point, or enter coordinates.)
Diameter/<Radius of sphere>: (Specify a distance, or type D.)
Number of longitudinal segments <16>: (Type a value or press Enter to accept the default number.)
Number of latitudinal segments <16>: (Type a value or press Enter to accept the default number.)
If Dynamic Dimensions are active, you can enter the radius in the dynamic dimension entry field.
Specifies the center point of the sphere; enter x,y- or x,y,z-coordinates, or pick a point in the drawing. |
Specifies the radius. |
Specifies the diameter. |
Specifies the number of segments of the circles perpendicular to the vertical axis of the sphere. |
Specifies the number of segments of the circles through to the vertical axis of the sphere. |
Grips Editing
Ai_Dish - draws 3D dishes as mesh surfaces.
RuleSurf - draws ruled surfaces as mesh surfaces.
TabSurf - draws tabulated surfaces as mesh surfaces.
© Menhirs NV. All rights reserved. |
