Converts drawings to from CTB (color-based plotting) to STB (plot styles).
command bar: convertpstyles
: convertpstyles
Click OK.
The next dialog box appears:
Choose an STB file, and then click Open.
BricsCAD reports in the command bar:
Drawing converted from Color Dependent mode to Named plot style mode.
No options.
Procedures
To convert a drawing from STB to CTB file type
To convert a drawing from CTB to STB file type
Layer - assigns plot styles to layers.
PlotStyle - sets the current plot style.
Print - plots drawings with plot styles.
Properties - changes plot styles assigned to entities.
© Menhirs NV. All rights reserved. |
