Commands: STYLESMANAGER
The Plot Styles Manager is a window that lists plot style table files (CTB and STB files).
The Plot Styles Manager allows you to:
Create Color-dependent Plot Style (CTB) and Named Plot Style files (STB) using the Create a Plot Style Table wizard.
Edit existing Plot Style Table files.
To open the Plot Styles Manager
Do one of the following:
To create a new plot style table
CTB (Color-dependent Plot Style Table) - bases plots on entity colors. Plotting parameters, such as pen thickness and linetype, are matched to the color of entities. This system is older and less flexible than named plot styles, but is the default in all new drawings. Creates a CTB file.
STB (Named Plot Style Table) - bases plots on plot styles. Plotting parameters can be given to every entity and every layer. This system is new and more flexible, but may be incompatible with other software that reads DWG files. Creates an STB file.
The Plot Style Table Editor dialog displays.
To create a new plot style table in the Print dialog
NOTE |
The above procedure creates a CTB file in CTB-type drawing and a STB file in a STB-type drawing. |
To edit a plot style table in the Print dialog
