Pro, Platinum
Pro, Platinum
Pro, Platinum
Revolves 2D closed entities to turn them into 3D solids.
command bar: revolve
alias: rev
menu bar: Model | 3D Solids | Revolve
toolbar: 3D Solids |
: revolve
Select entities: (Choose one or more closed 2D entities.)
Entities in set: 1
Select entities: (Choose more closed 2D entities, or press Enter to continue.)
Specify start point for axis of revolution or define axis by Object/Xaxis/Yaxis: (Enter an option.)
Specify angle of revolution <360>: (Enter the number of degrees, pick two points, or press Enter for the default.)
This command revolves only closed entities: circles, ellipses, closed polyline, closed splines, and regions.
The axis can be defined by two points; a line or a polyline segment; or the x or y axis.
The axis must be outside of the entity being revolved.
Depending on the value of the DELOBJ (Delete Entity) system variable, the defining entities are either retained or deleted or you are prompted whether to keep or delete the source entities.
dmRevolve - creates 3D solids by revolution of closed 2D entities or regions about an axis.
Sweep - creates a 3D solid by sweeping a closed 2D entity along a path.
© Menhirs NV. All rights reserved. |
