Union
BricsCAD (Windows) Pro, PlatinumBricsCAD (Mac) Pro, PlatinumBricsCAD (Linux) Pro, Platinum
Performs Boolean union operations on 3D solids and 2D regions; adds one to another to form a single entity.
command bar:  union
alias:  uni
menu bar:  Model | 3D Solid Editing | Union
toolbar:  3D Solid Editing |
: union
Select ACIS objects to union: (Choose one or more 3D solids and/or 2D regions.)
Entities in set: 2
Select ACIS objects to union: (Choose more ACIS entities, or press Enter to complete the command.)
The resulting solid takes on the properties of the first-picked solid.
3D solids that are joined through the Union command often look no different after the operation:
This command also applies to regions:
Specifies the ACIS entities to join into a single entity.
The resulting entity takes on the properties of the ACIS entity selected first.
This command also joins regions and 3D solids into a single entity.
BimSplit - splits segments of wall-like solids into separated solids.
