Pro, Platinum
Pro, Platinum
Pro, Platinum
Generates additional projected views from an existing drawing view.
command bar: viewproj
menu bar: View| Generated Views | Projected Views
toolbar: Generated Views |
: viewproj
Select drawing view: (Click inside an existing drawing view.)
Select position for projected view [Isometric style] <Cancel>: (Position the projected views with respect to the existing drawing view. Right click to stop adding projected views.)
4 orthogonal and 4 isometric views can be generated from an existing drawing view.
Isometric style |
Sets the style for isometric views. Prompts you: Create isometric views as [3D views / 2D views] <2D>: The options are:
ViewBase - generates associative orthographic and standard isometric views of a 3D solid model in a paper space layout.
ViewExport - exports the content of drawing views and sections obtained by VIEWBASE and VIEWSECTION to the Model Space of the drawing.
ViewDetail - creates a detail view of a portion of a standard generated drawing at a larger scale.
ViewDetailStyle - allows to specify the visual format of detail views and detail symbols.
ViewEdit - allows changing the scale and the hidden line visibility of drawing views.
ViewExport - Exports the content of drawing views obtained by VIEWBASE and VIEWSECTION to the Model Space of the drawing or to a new drawing.
ViewSection - creates a cross section view based on a standard drawing view generated by the VIEWBASE command in a paper space layout.
ViewSectionStyle - allows to specify the visual format of section views and section lines.
ViewUpdate - updates a selection of drawing views or sections when VIEWUPDATEAUTO = 0.
