The Units command sets units of linear and angular measurements through the Settings dialog box.
The -Units command sets units of linear and angular measurements in the command bar.
The INSUNITS system variable defines a drawing units value for automatic scaling when inserting blocks or attaching Xrefs.
The AUNITS system variable defines the angular unit type.
You can enter angles in any of 5 formats:
