Commands: RTROT, RTROTCTR, RTROTF, RTROTX, RTROTY, RTROTZ, DDVPOINT, -VIEW, PLAN and VPOINT
The Rtrot (Real-Time Constrained Sphere) command rotates 3D drawings in real-time.
The Rtrotctr (Real-time Sphere Center) command freely rotates 3D drawings in real-time about a user-defined center point.
The Rtrotf (Real-time Free Sphere) command freely rotates 3D drawings in real-time.
The Rtrotx , Rtroty and Rtrotz commands rotates 3D drawings in real-time about the x, y or z screen axis.
The Ddvpoint command sets 3D viewpoints or plan view, through a dialog box (short for "dynamic dialog view point").
The Plan command displays the plan viewpoint of drawings.
The Vpoint command changes the 3D viewpoint.
In order to view your 3D drawings from any angle, you can rotate a view. The Real-Time Motion tools of BricsCAD allow you to rotate a view in real-time. You can rotate the view about the X, Y or Z screen axis or in any direction (real-time sphere). If the Continuous Motion variable is set, the view rotation continues until you conclude the Real-Time Motion command.
See also: View manipulation using the mouse.
NOTE |
'Real-time' commands should not be used when drawing in 2D. Use the Plan View tool to restore top view. |
The Look From control allows to select a number of preset views such as orthographic views and isometric views. By default the Look From control displays in the top right corner of the graphic screen.
If the UCSORTHO system variable is ON an orthographic UCS is restored automatically when the related orthographic view is chosen on the Look From control.
The behavior of the Look From control depends on a number of system variables and user preferences
Name |
Title |
Description / Options |
NAVVIEWCUBEDISPLAY |
Look From Display |
Controls whether the Look From control displays. |
NAVVIEWCUBELOCATION |
Look From Location |
Controls the location of the Look From control in the graphic screen. The options are: 0: Top right corner. 1: Top left corner 2: Bottom left corner 3: Bottom right corner |
NAVVIEWCUBEOPACITY |
Look From Opacity |
Sets the opacity of the Look From control when not active. Values between 1 (invisible) and 100 (no dimming) are accepted. |
NAVVIEWCUBEORIENT |
Look From Orientation |
Specifies the view orientation reference: either the WCS (World Coordinate System or the current UCS (User Coordinate System). |
LookFromFeedback |
Look From Feedback |
Controls the display and location of tooltips. 0: No tooltips 1: Tooltips next to the Look From control. 2: Tooltips in the status bar. |
Look From Direction Mode |
Specifies the number of available view directions. Holding down the Ctrl-key switches between top-down and bottom-up view directions 0: Orthogonal views only (6 directions).
1: 6 Orthogonal views and 8 Isometric views (14 directions).
2: 4 Rotated orthogonal, 6 Orthogonal and 8 Isometric views (18 directions)
3: 8 Rotated isometric, 4 Rotated orthogonal, 6 Orthogonal and 8 Isometric views (26 directions).
LookFromZoomExtents |
Look From Zoom Extents |
Determines whether a 'zoom extents' is performed whenever a new view direction is selected. |
Isometric mode is best used in 3D models.
Twist mode is best used in 2D drawings.
In Twist mode, the Loofk From control allows to rotate the view around the screen Z-axis
The command bar reads: >> Press ENTER or Esc to complete, or right click to display context menu ...
Rotating a view about the view X-axis
Rotating a view about the view Y-axis
Rotating a view about the view Z-axis
The Preset Viewpoint dialog opens.
Then choose either 45°, 15° or 5°.
45° display mode |
In 15° or
5° mode
click in the inner area of the Horizontal and Vertical fields to choose a 45° display mode viewpoint.
Click in the outer area of the Horizontal and Vertical fields to choose another angle.
Horizontal for East, North, West and South.
Downwards for the other directions.
If both the down- and left-arrow show in the Vertical field, the default vertical view directions are active.
The view is updated as you click.
NOTE |
Use the Isometric Views toolbar for standard view rotations: top, front, back, left, right and isometric views. |
The command bar reads: Plan view of: UCS/World/<current UCS>:
A prompt menu opens:
NOTES |
© Menhirs NV. All rights reserved. |
