Commands: PUBLISH, -PUBLISH, SHEETSET
The Publish command allows to print a sheet list (= a list of model space or paper space layouts) to a printer. A sheet list can be saved to a DSD (Drawing Set Description) file.
The SheetSet command manages sheet sets and allows to print, publish or etransmit a sheet set as a whole or a selection of sheets. A sheet set is saved to a DST file (Sheet Set Data) file.
