BmBrowser
Platinum
Platinum
Platinum
Toggles the visibility of the Mechanical Browser window.
command bar: bmbrowser
menu bar: Assembly | Mechanical
Browser
ribbon: Assembly | Tools | Mechanical
Browser
toolbar: Assembly |
: bmbrowser
The Mechanical Browser allows navigation on the
hierarchy of mechanical components for the current drawing and
calling different commands for the inserts.
Component Name
Standard Part Component Insert (= block
reference)
Collapsed Component Insert (= external
reference)
Expanded Component Insert (= external
reference)
Standard Part Subcomponent Insert (= nested block
reference)
Subcomponent Insert (= nested external
reference)
3D geometrical constraints
Properties of the selected item
- Name: name of
the component in the assembly
- Component
name: Name of the component in the source file
- Description:
optional description of the component
- Visible:
controls the visibility of the component in the drawing
- Visual Style:
defines the visual style of the component (see also BmVStyle command).
- File: source
file of the component
- Density:
density used by the BmMassProp
command.
Icons
Rendered visual style
Wireframe visual style
Hidden
Component that does not contain subcomponents
Component that contains subcomponents
* External components have a green arrow added:
or
Model
Group by Entity
Groups 3d constraints by entity or mechanical
component they are applied to.
Group by Type
Groups mechanical components and 3d constraints
in separate trees.
Groups 3d constraints by type: e.g. distance
constraints and radii constraints are grouped separately.
C
Sort Alphabetically
When pressed ( ) the mechanical components and 3d constraints are sorted
alphabetically,
When depressed ( ) the mechanical components and 3d constraints are listed in
the order they were added to the assembly.
Context Menus
Main Component context menu
Right click the main component name:
Show all: Displasy
all components in the assembly.
Update: Updates the
hierarchy of mechanical components for the current drawing in case
referenced drawing files of sub-components have been modified.
Visual Style: All by
Viewport: Applies the current Visual Style to all
components in the assembly (see the ShadeMode command).
Switch all to
local: Switches all components
to internal components (see the BmLocalize the command).
Switch all to
external: Switches all components to external components
(see BmExternalize the
command).
Add new parameter:
Creates a new parameter in the assembly.
Collapse all:
collapses the main component and all components and
subcomponents.
Expand all: expands
the main component and all components and subcomponents.
Right click a component name.
External components context menu (left), local
components context menu (right):
Open: Opens the
referenced drawing (see the BmOpen
command).
Open a copy: Opens a
copy of a component insert as a new drawing (see the BmOpenCopy command).
Select: Selects the
component.
Hide ( ) / Show ( ): Hides or shows the selected component.
Visual Style:
Displays the Visual Style menu.
Visual Styles that
are saved in the current drawing are available.
By Viewport: Renders
the selected component according to the current viewport shademode
All by Viewport:
Renders all components according to the current viewport
shademode (see the ShadeMode
command).
Replace: Replaces a
component insert (see the BmReplace
command). Replacing a local insert turns it into an external
insert.
Replace all inserts:
Replaces all inserts that refer to the same source (see the
BmReplace command). Replacing local
inserts turns them into external inserts.
Switch to local:
Switches an external component to an internal component (see the
BmLocalize command).
Switch to external:
Switches an internal component to an external component (see the
BmExternalize command).
Dissolve: Dissolves
a mechanical component inserted in the current drawing (See the
BmDissolve command).
Delete: Removes the
selected component and its subcomponents from the assembly.
Collapse all:
subcomponents.
Expand all: expands
Subcomponent context menu
Right click a component name:
Open: Opens the
command)
Hide ( ) / Show ( ): Hides or shows the selected subcomponent.
Visual Style: See Component context menu.
Collapse all: collapses the main component and
Expand all: expands the main component and all
Constraint context menu
Right click a constraint:
Delete: Deletes the selected
constraint.
Flip side: Allows to change the
relative position of an entity (vectors normal of the selected
faces point in the same direction or in the opposite direction).
This option can be applied to Parallel, Coincident and Concentric constraints only and on condition the
constraint is applied to faces.
Disable/Enable: Toggles the selected
constraint ON/OFF.
The Enabled field in the Properties
grid is adjusted accordingly.
Select geometry: Selects the
geometry, that is affected by the constraint, in the drawing.
Collapse all:
subcomponents.
Expand all: expands
Properties
Main component properties
Click the main component name:
Click the Name
field to edit the main component name.
Click the Description field to type a description.
Expand the Density settings, then select No from the Inherit
density options and type a value in the Value field.
The density of the main component is applied to all components and
subcomponents that have the Inherit
density setting: Yes.
Component insert properties
Click the component name:
Click the Name
field to edit the insert name.
Click the Visible
field, then select Yes or
No from the list button.
If set to Yes all subcomponents of
which the visibility is On are
visible.
If set to No, no subcomponents are
visible, regardless their visibility setting.
Click the Visual
style field, then select a visual style from the list
button.
The selected visual style is applied to the component insert,
visual styles of the subcomponents different from By Viewport are not affected.
Subcomponent properties
Click the subcomponent name:
Click the Visible
field, the select Yes or No from the list button.
If set to Yes, the subcomponent is
visible only if its parent component is visible too.
Click the Visual
button.
Selection Methods
Select a
component in the model.
The component highlights in the Mechanical Browser.
Click a
component in the Mechanical Browser
The component highlights in the drawing.
Library
Click the Library button to access
the standard parts library.
See the BmHardware
command.
Report
Some commands use the Report panel to report the output; e.g.
DmRepair and SmSelectHardEdges.
BmDependencies - lists all
files, containing component definitions inserted in the assembly,
in the command window.
BmExternalize - switches
internal components to external components.
BmHardware - inserts a
standard hardware part as a mechanical component in the current
drawing.
BmLocalize - switches external
components to internal components.
BmOpen - opens the component insert
drawing.
BmOpenCopy - opens a copy of a
component insert as a new drawing.
BmReplace - replaces a component
insert.
BmUpdate - reloads all referenced
components from external files and updates BOM tables.
-ToolPanel - allows to control
the display of tool panels, such as the Properties Bar, the Ribbon
or the Sheet Sets panel from the command line.
© Menhirs NV. All rights reserved. |
