Platinum
Platinum
Platinum
Converts local components to external components.
command bar: bmexternalize
menu bar: Assembly | Switch Component to External
ribbon: Assembly | Modify | External ![]()
toolbar: Assembly | ![]()
: bmexternalize
Select component instances / <Entire model>: (Select a local component.)
Entities in set: 1
Select component instances / <Entire model>: (Select a local component or press Enter.)
A file dialog displays:
Do one of the following:
Press the Save button to accept the default name, which is the name of the selected local component.
Type a name in the File Name field, then click the Save button.
This procedure is repeated for each of the selected local components.
For each of the local components in the assembly a file dialog displays. Do one of the following:
BmDissolve - dissolves a mechanical component inserted in the current drawing.
BmLocalize - converts external components to local components.
BmReplace - replaces a component insert.
