Allows to create and edit render presets, and to set the current render preset through a dialog box.
command bar: renderpresets
menu bar: Tools | Drawing Explorer | Render Presets
: renderpresets
Displays the Render Presets section of the Drawing Explorer dialog box:
Creates a new render preset definition.
Deletes the currently selected user defined render preset(s). It is not possible to delete predefined render presets: Draft, Low, Medium, High and Presentation. |
Sets the selected render preset current. The current render preset is applied when using the Render command or when printing using the shade plot type Rendered as defined in Shade Plot setting in the Page Setup or the Print dialog. The name of the current render preset displays between brackets: e.g. Current Settings (Medium)? Optionally overrides can be defined in the the editor pane. If
overrides exist, an asterisk displays in front of the current
render preset name: e.g. |
Displays the Detail View of the render presets. |
Displays the Icon View of the render presets. |
Settings |
It is not possible to edit predefined render presets: Draft, Low, Medium, High and Presentation, except for Processing > Tile order. |
If On, uses material definitions for rendering. |
If On, calculates shadows. |
If On, calculates ray tracing. Max. depth, Max refections and Max refractions define the number of iterations for ray tracing calculations. |
Tile size: sets the size of the tiles the rendered image is processed. Tile order: When you render to window the rendered image is generated tile by tile. This setting will define the order in which the tiles are generated. The options are:
Render - generates a photorealistic rendering using materials and lights through a dialog box.
-Render - generates a photorealistic rendering using materials and lights through the command bar.
