Circle object
Class AcadCircle
Member of BricscadDb
The Circle object represents a full circle. To create a circle use the AddCircle method. To access the Circle object, use the following methods and properties:
Methods Properties
ArrayPolar Application
ArrayRectangular Area
Copy Center
Delete Circumference
GetBoundingBox Diameter
GetExtensionDictionary Document
GetXData Handle
Highlight HasExtensionDictionary
IntersectWith Hyperlinks
Mirror Layer
Mirror3D Linetype
Move LinetypeScale
Offset Lineweight
Rotate Material
Rotate3D Normal
ScaleEntity ObjectID
SetXData ObjectName
TransformBy OwnerID
Update PlotStyleName
  Radius
  Thickness
  TrueColor
  Visible
