Dim3PointAngular object
Class AcadDim3PointAngular
Member of BricscadDb
A dimension measuring the angular distance between three points. To create a 3-point angular dimension, use the AddDim3PointAngular method. To access the Dim3PointAngular object, use the following methods and properties:
Methods Properties
ArrayPolar AngleFormat
ArrayRectangular AngleVertex
Copy Application
Delete Arrowhead1Block
GetBoundingBox Arrowhead1Type
GetExtensionDictionary Arrowhead2Block
GetXData Arrowhead2Type
Highlight ArrowheadSize
IntersectWith DecimalSeparator
Mirror DimensionLineColor
Mirror3D DimLine1Suppress
Move DimLine2Suppress
Rotate DimLineInside
Rotate3D Document
ScaleEntity ExtensionLineColor
SetXData ExtensionLineExtend
TransformBy ExtensionLineOffset
Update ExtLine1EndPoint
  ExtLine1StartPoint
  ExtLine1Suppress
  ExtLine2EndPoint
  ExtLine2StartPoint
  ExtLine2Suppress
  Fit
  ForceLineInside
  Handle
  HasExtensionDictionary
  HorizontalTextPosition
  Hyperlinks
  Layer
  Linetype
  LinetypeScale
  Lineweight
  Measurement
  Normal
  ObjectID
  ObjectName
  OwnerID
  PlotStyleName
  Rotation
  ScaleFactor
  StyleName
  SuppressLeadingZeroes
  SuppressTrailingZeroes
  TextColor
  TextFill *
  TextFillColor *
  TextGap
  TextHeight
  TextInside
  TextInsideAlign
  TextMovement
  TextOutsideAlign
  TextOverride
  TextPosition
  TextPrecision
  TextPrefix
  TextRotation
  TextString
  TextStyle
  TextSuffix
  ToleranceDisplay
  ToleranceHeightScale
  ToleranceJustification
  ToleranceLowerLimit
  TolerancePrecision
  ToleranceSuppressLeadingZeroes
  ToleranceSuppressTrailingZeroes
  ToleranceSuppressZeroFeet
  ToleranceSuppressZeroInches
  ToleranceUpperLimit
  TrueColor
  VerticalTextPosition
  Visible
