Leader object
Class AcadLeader
Member of BricscadDb
The Leader object represents a line leading from a feature of the drawing to an annotation, such as a dimension. To create a leader, use the AddLeader method. To access the Leader object, use the following methods and properties:
Methods Properties
ArrayPolar Annotation
ArrayRectangular Application
Copy Color
Delete Coordinates
Erase Document
GetBoundingBox EntityName
GetExtensionDictionary
GetXData Handle
Highlight HasExtensionDictionary
IntersectWith Hyperlinks
Mirror Layer
Mirror3D Linetype
Move LinetypeScale
Rotate Lineweight
Rotate3D Normal
ScaleEntity Parent
SetXData PlotStyleName
TransformBy StyleName
Update TrueColor
  Type
  VerticalTextPosition
  Visible
