Class AcadRay
Member of BricscadDb
The Ray object is a line that starts at a designated point and runs infinitely. To create a Ray object, use the AddRay method. To access a ray, use the following methods and properties:
Methods | Properties |
ArrayPolar | Application |
ArrayRectangular | BasePoint |
Copy | DirectionVector |
Delete | Document |
GetBoundingBox | Handle |
GetExtensionDictionary | HasExtensionDictionary |
GetXData | Hyperlinks |
Highlight | Layer |
IntersectWith | Linetype |
Mirror | LinetypeScale |
Mirror3D | Lineweight |
Move | Material |
Rotate | ObjectID |
Rotate3D | ObjectName |
ScaleEntity | OwnerID |
SetXData | PlotStyleName |
TransformBy | SecondPoint |
Update | TrueColor |
Visible |
© Menhirs NV. All rights reserved. |
