Distributes entity copies in an evenly spaced rectangular, polar or path array.
command bar: array
alias: ar
: array
Select entities: (Select an entity)
Entities in set: 1
Select entities: (Select more entities or press Enter to stop selecting entities.)
Enter array type [Rectangular/PAth/POlar] <Rectangular>: (Choose an array type or press Enter to accept the default).
The default array type is saved through the ARRAYTYPE system variable.
Rectangular |
Distributes entity copies into any number of rows, columns, and levels. See the ArrayRect command. |
Path |
Distributes entity copies evenly along a path into multiple rows, and levels. See the ArrayPath command. |
Polar |
Distributes entity copies evenly in a circular pattern about a center point or axis of rotation, using multiple rows, and levels. See the ArrayPolar command. |
3dArray - creates 3D arrays.
-Array - creates a polar or rectangular array of entities; displays prompts at the command bar.
ArrayClassic - Creates a polar or rectangular array of entities through a dialog box.
ArrayEdit - allows editing associative array entities and their source entities.
ArrayPath - distributes entity copies evenly along a path into multiple rows, and levels.
ArrayPolar - distributes entity copies evenly in a circular pattern about a center point or axis of rotation, using multiple rows, and levels.
ArrayRect - distributes entity copies into any number of rows, columns, and levels.
MInsert - inserts arrays of blocks.
