Mirror
Mirrors entities about a mirror line in a 2D plane.
command bar:  mirror
alias:  mi
menu bar:  Modify | 2D Mirror
toolbar:  Modify |
: mirror
Select entities to mirror: (Choose one or more entities.)
Entities in set: 1
Select entities to mirror: (Choose more entities, or press Enter to continue.)
Start of mirror line: (Pick a point, or enter x,y coordinates.)
End of mirror line: (Pick another point.)
Delete the original entities? [Yes-delete entities/No-keep entities] <No-Keep entities>: (Type Y or press Enter to accept the default option: keep the original entities.)
Specifies the start point for the line about which entities are mirrored.
This line is temporary; as soon as you pick the second point, it disappears.
To mirror vertically or horizontally, hold down the Shift key when specifying the second point or use Polar Tracking.
End of mirror line
Specifies the second point of the mirror line.
Determines whether the original entities are erased:
  • Y - erases the original entities, leaving only the mirrored ones.
  • N - does not erase the original entities, leaving them in place.
Procedures
Mirroring entities about a line
Mirroring entities about a plane
To mirror entities using grips
Mirror3D - mirrors entities in 3D space.
InsertAligned - inserts mirrored blocks.
