Draws point entities.
command bar: point
alias: po
menu bar: Draw | Point
toolbar: Draw | ![]()
: point
Location of point or [point Settings.../Multiple points]: (Pick a point, enter x,y,z coordinates, or enter an option.)
Specifies the location of the point in the drawing. Pick a point, or enter x,y,z coordinates. |
Displays the Points section of the Settings dialog box:
Point display mode - specifies the look of points. Point display size - specifies the size of points. |
Repeats the command to draw multiple points; keeps prompting you: Location of point or [point Settings...] - specify a point or press Enter to stop. |
Procedures
Defining the point display settings
Grips Editing
Points can be edited directly through grips:
Select the point. Notice that it has one grip.
Drag the grip to move the point.
DdPType - defines the size and shape of points.
Divide - places evenly-spaced points along entities.
Measure - places equi-distant points along entities.
