Sheet Metal
Sheet Metal
Sheet Metal
Removes a bend or a junction by restoring a hard edge between two flanges; removes a flange with all the bends adjacent to it. The adjacent flanges are extended up to a junction configuration with the flange being deleted.
command bar: smdelete
menu bar: Sheet Metal | Delete Feature
toolbar: Sheet Metal | ![]()
ribbon: Sheet Metal | Modify |
: smdelete
Select feature faces or thickness faces: (Select an item.)
Entities in set: 1
Select feature faces or thickness faces: (Select another item or right click.)
Selected bend faces |
The selected bends are replaced by hard edges |
No options.
SmBendCreate - converts hard edges (sharp edges between flange faces) into bends.
SmConvert - automatically recognizes flanges and bends in a 3D solid.
SmDissolve - removes sheet metal data from the selected faces.
SmFlangeConnect - closes gaps between two arbitrarily oriented flanges.
SmFlangeEdge - creates one or more flanges to a sheet metal part by pulling one or more edges of an existing flange.
SmFlangeSplit - splits a flange along a line drawn on its face.
SmJunctionCreate - converts hard edges (sharp edges between flange faces) and bends into junctions.
SmReliefCreate - makes proper corner and bend reliefs. Corner reliefs are built on corners which have three or more adjacent flanges. Bend reliefs are built on the start and end of a flange edge .
