Places tolerance symbols in drawings.
command bar: tolerance
alias: tol
menu bar: Dimensions | Tolerance
toolbar: Dimensions | ![]()
: tolerance
Select tolerance symbols and enter values, and then click OK.
Select location for tolerance: (Specifies the insertion point for the tolerance symbol.)
Material conditions |
Symbol |
Definition |
At maximum material condition (MMC), a feature contains the maximum amount of material stated in the limits. |
At least material condition (LMC), a feature contains the minimum amount of material stated in the limits. |
Regardless of feature size (RFS) indicates that the feature can be any size within the stated limits. |
Inserts a tolerance symbol; displays dialog box:
Choose a symbol, and then click OK. |
Tolerance 2 |
Specifies tolerance specification:
Diameter - toggles the diameter symbol when clicked. Value - specifies the tolerance value. Material condition - displays dialog box when clicked:
Datum 2 Datum 3 |
Specifies the datum reference:
Value - specifies the datum value. Material condition - click to display the Material Condition dialog box. |
Specifies the height of the tolerance symbols. |
Specifies datum indentifier, such as Datum A. |
Toggles the projected tolerance zone symbol:
Procedures
To create a geometrical tolerance frame
Grips Editing
Tolerances can be edited directly through grips:
Select the tolerance. Notice that it has one grip.
Drag the grip to move the tolerance.
Leader - attaches tolerances to leader lines.
DimOrdinate - draws x and y ordinate dimensions.
