Draws leaders.
command bar: leader
aliases: le, lead
: leader
Start of leader: (Pick a point.)
Next point: (Pick a point.)
To point [Format/Undo/Annotation] <Annotation>: (Pick a point, or enter an option.)
Leaders consist of the following parts:
Specifies the next vertex. Pick a point or press Enter to stop adding vertices and start the Annotation option. |
Specifies the leader style; prompts you: [Arrow/None/SPline/STraight/Exit] <Exit> - enter an option.
Undoes the last leader line segment. |
Starts adding text to the end of the leader line. The annotation is created as an Mtext entity; prompts you: First line of annotation text <options> - Press Enter to choose Options or type the first line of text, then press Enter. Next line of annotation text - Press Enter to stop adding text or type the next line, then press Enter.
Caution: the annotation is independent of the leader line; when moving a leader, be sure to include the annotation in the selection set. |
Specifies the type of annotation; prompts you: Dimension text options [Block/Copy/None/Tolerance/Mtext] <Mtext> - enter an option.
DimLeader - places leaders with text, blocks, entities, or tolerances.
QLeader - draws leaders. Lets you specify the properties of the leader through a dialog box and reuse them for a series of leaders.
MLeader - creates multileader entities using the current multileader style.
