Displays the Properties panel with properties of selected entities.
command bar: properties
aliases: ch, pr, props, mo, ddchprop, ddmodify
menu bar: Modify | Properties
toolbar: Standard | ![]()
: properties
Displays a palette with varying content:
When no entities are selected:
General: shows the current entity creation
settings.
View: shows the current View properties (see the
View command).
Misc: shows the current Annotation scale.
When one entity is selected: reports the properties of the selected entity.
When two or more entities are selected: reports the shared properties of the selected entities.
Options |
Reports the number of selected entities. Click to see the number of each entity type in the current selection set:
Select an entity type in the list to see the shared properties of all entities of this type in the current selection set. |
Switches between Properties and Quick Select mode (See also the Qselect command). |
Reports the current color. Allows to change the color of selected entities:
See Color command. |
Reports the current layer name. To change the layer of selected entities:
See Layer command. |
Reports the current linetype. To change the linetype of selected entities: 1. Click the droplist. and then choose another name.
2. Choose Load to access the Load Linetypes dialog box. See Linetype command. |
Reports the current linetype scale factor.
To change the linetype scale, enter a new value. See LTSCALE system variable, |
Reports the current plot style. To change the plot style of selected entities:
(This property is available only when plot styles are enabled for the drawing. See PlotStyle command.) |
Reports the current lineweight. To change the lineweight of selected entities:
See LWeight command. |
Reports the current hyperlink. To change the hyperlink of selected entities: 1. Enter a new URL.
2. Click the
See Hyperlink command. |
Reports the current entity thickness. To change the thickness of selected entities:
See Elev command. |
Reports the current Material definition of the selected entity. To change, click the settings field, then select a material from the drop-down list. See the Materials command to manage material definitions. |
Reports the current position of the Camera and Target properties of the view. See the Camera command. |
Reports the current value of the PERSPECTIVE system variable. Allows to switch the perspective view mode on/off. |
Reports the current value of the LENSLENGTH system variable. Allows to edit the value of the LENSLENGTH system variable. |
Reports the current view angle. Allows to edit the camera view angle. Editing this value affects the value of the LENSLENGTH system variable. |
Reports the dimensions of the current view in drawing units. |
Reports the current visual style. Allows to select a different visual style. See the VisualStyles command. |
Reports the current value of the CANNOSCALE system variable. Allows to edit the value of the CANNOSCALE system variable. All scales defined in the drawing are available (see the ScaleListEdit and -ScaleListEdit commands) |
Other properties vary, depending on the entity selected.
Area - reports the area, circumference, and perimeter of entities.
AttEdit - edits attribute values and properties.
AttRedef - redefines a block and updates associated attributes.
AttSync - synchronizes attribute definitions in all block references of a specified block definition.
BattMan - manages the attributes of a block definition.
Dist - reports the 2D and 3D distances between two points.
EAttEdit - edits attribute values and most properties.
Id - reports the x,y,z coordinates of picked points.
Layer - assigns properties to layers.
List - lists the area and other parameters of entities in the command bar.
MassProp - reports the properties of solid models and regions.
PropertiesClose - closes the Properties panel.
-ToolPanel - allows to control the display of tool panels, such as the Properties Bar, the Ribbon or the Sheet Sets panel from the command line.
