The Units command sets units of linear and angular measurements through the Settings dialog box.
The -Units command sets units of linear and angular measurements in the command bar.
The INSUNITS (Insertion Units) system variable defines a drawing units value for automatic scaling when inserting blocks or attaching Xrefs.
Any length, area or volume property can be displayed using the unit(s) preferred by the user.
The unit defined by INSUNITS is used as the base unit for any requested unit conversions. If INSUNITS = 0 (undefined) the PROPUNITS mechanism is disabled because the base drawing unit is undefined.
NOTES |
Name |
Title |
Insertion Units |
Defines the value of 1 Drawing Unit (DU), which is used for automatic scaling when inserting or attaching blocks, images or Xrefs. When both INSUNITS and PROPUNITS are ON, Length, Area, Volume and/or Inertia properties will be formatted with a dedicated unit. |
Measurement |
Sets drawing units as Imperial or Metric. The MEASUREMENT system variable controls whether ANSI or ISO hatch pattern and linetype files are used. |
Property Units |
Defines which property values are automatically formatted with a dedicated unit when INSUNITS is not zero. The value is stored as a bitcode, using the sum of the values of all selected options: 1 = format lengths 2 = format areas 4 = format volumes 16 = format dynamic dimensions |
Linear Unit Precision |
Sets the number of decimal places displayed for linear units. |
Area Precision |
Sets the number of decimal places displayed for areas when the Area bit of PROPUNITS is ON. If set negative, the value of LUPREC is used. |
Volume Precision |
Sets the number of decimal places displayed for volumes when the Volume bit of PROPUNITS is ON. If set negative, the value of LUPREC is used. |
Length Units |
Defines a list of units used for displaying lengths when the Length bit of PROPUNITS is ON. If empty, all lengths display in the current drawing unit, as defined by INSUNITS. If multiple units are selected, the unit that fits best is used.
Area Units |
Defines a list of units used for displaying areas when the Area bit of PROPUNITS is ON. If empty, all lengths display in the current drawing unit, as defined by INSUNITS. If multiple units are selected, the unit that fits best is used.
Volume Units |
Defines a list of units used for displaying volumes when the Volume bit of PROPUNITS is ON. If empty, all lengths display in the current drawing unit, as defined by INSUNITS. If multiple units are selected, the unit that fits best is used.
UNITMODE |
Unit Mode |
Specifies how Imperial units display. 0 = Displays fractional, feet-and-inches, and surveyor's angles in "report" format using spaces as delimiters. 1 = Displays fractional, feet-and-inches, and surveyor's angles in "input" format without including spaces and, in some cases, substituting dashes for spaces |
The AUNITS system variable defines the angular unit type.
You can enter angles in any of 5 formats:
