Class AcadLineType
Member of BricscadDb
The Linetype object defines the appearance of a line. A line can be solid (continuous) or a pattern of dashes, dots, and blank spaces. To access the Linetype object, use the following methods and properties:
Methods | Properties |
Delete | Application |
GetXData | Description |
GetExtensionDictionary | Document |
SetXData | Handle |
HasExtensionDictionary | |
Name | |
ObjectID | |
ObjectName | |
OwnerID |
© Bricsys NV. All rights reserved. |
