Closed property
Sets or returns if the entity is closed.
Syntax
BooleanVariable = object.Closed
Where:
     BooleanVariable specifies whether the object is closed (True) or not (False).
     Object is the entity a 3DPolyline, LightweightPolyline, Polyline, Spline for which you set or return the Closed property.
Examples...
Closed property example
