Class AcadLWPolyline
Member of BricscadDb
The LWPolyline (lightweight polyline) object represents a drawing entity composed of one or more connected line or arc segments treated as a single entity. To create a polyline, use the AddPolyline method. To edit or obtain information about a line, use the following methods and properties:
Methods | Properties |
AddVertex | Application |
ArrayPolar | Area |
ArrayRectangular | Closed |
Copy | ConstantWidth |
Delete | Coordinate |
Explode | Coordinates |
GetBoundingBox | Document |
GetBulge | Elevation |
GetExtensionDictionary | Handle |
GetWidth | HasExtensionDictionary |
GetXData | Hyperlinks |
Highlight | Layer |
IntersectWith | Length |
Mirror | Linetype |
Mirror3D | LinetypeGeneration |
Move | LinetypeScale |
Offset | Lineweight |
Rotate | Material |
Rotate3D | Normal |
ScaleEntity | ObjectID |
SetBulge | ObjectName |
SetWidth | OwnerID |
SetXData | PlotStyleName |
TransformBy | Thickness |
Update | TrueColor |
Visible |
© Bricsys NV. All rights reserved. |
