bim:get-roomassignedbuilding
(bim:get-roomassignedbuilding
roomEntity)
Returns the name of the building where the BIM
room specified by roomEntity
is assigned to.
Arguments |
roomEntity room entity of an existing room (ename), as returned by (bim::create-room) and (bim::create-associativeroom), or other room functions |
Return |
the name of the building (string) where "roomEntity" is assigned to, or NIL if no building is assigned or the specified "roomEntity" is not a valid room |
Example |
roomEnt1) "Tower" |
Remarks |
since V21 : this function
also works with the new "Spaces" objects; |
