bim:list-propertysets
(bim:list-propertysets [categoryId |
categoryName])
This function returns a list of all defined
PropertySets of (optionally) specified NameSpace
categoryId | categoryName.
Arguments
(optional)
specifies the NameSpace to where to retrieve
the PropertySets from (each category has an associated
NameSpace)
categoryId BIM property category ID, can be omitted
(bcBimCategoryUser is used then); see Category Constants
---or---
categoryName BIM category name as string (can be an empty string
for bcBimCategoryUser), see Category Constants
if omitted, the "User" NameSpace is
automatically used
Return
a list of PropertySet
entries, each entry is defined as :
(<name> <label> <visible>
<per-instance>)
the "visible" status (T/NIL) means whether the
PropertySet (and its Properties) is visible in
PropertiesPanel
the "per-instance" status (T/NIL) means
whether the PropertySet (and its Properties) is assigned "per
instance" to specific BIM objects only, or apply for any BIM
object
Example
(bim:create-propertyset
"TestSet" "---test---" T T) T
(bim:list-propertysets) (("TestSet"
"---test---" T T))
Remarks
the PropertySet name/label is
case-insensitive;
if the NameSpace (as indirectly specified by
categoryId resp. categoryName) does not exist, NIL is
returned;
