bim:pset-delete-property
(bim:pset-delete-property  ename
 propertyset  name)
This function deletes the specified
property name (of PropertySet propertyset) from
entity ename.
| Arguments | ename  (ename) the entity to remove the property from;
if ename is
NIL, then the property name
itself is removed from the
PropertySet |
| Return | T or NIL, indicating success or failures (like PropertySet does not exist) |
| Example | (bim:pset-delete-property ent "MyPropertySet" "MyTag-A") T |
| Remarks | if ename is NIL, then the
property name itself is removed from the PropertySet |
