fixed_height
The fixed_height attribute takes a boolean value (true or false), with default value false. It has different meaning on a dialog, as opposed to other tiles. Note: if a vertical alignment of a row and sibling child tiles with a uniform space distribution is desired, it is required to enable the fixed_height attribute for the row tile. Otherwise, the row occupies more space.
related tiles
All of the child tiles or a dialog can have an fixed_height attribute..
