row
A row is a dcl container with horizontal orientation: it places all its child tiles besides each other, from left to right.
Note: if a vertical alignment of a row and sibling child tiles with a uniform space distribution is desired, it is required to enable the fixed_height attribute for the row tile. Otherwise, the row occupies more space. Also, the row and its siblings should be placed into a column container, rather than directly inside the dialog.
related attributes
callbacks
