column
A column is a dcl container with vertical orientation: it places all its child tiles below each other, from top to bottom.
Note: if a horizontal alignment of a column and sibling child tiles with uniform space distribution is desired, it is required to enable the fixed_width attribute for the column tile. Otherwise, the column occupies more space. Naturally, the column and its siblings should be placed into a row container.
related attributes
callbacks
