BricsCAD specific DCL attributes
BricsCAD's DCL engine
supports a number of specific attributes (beyond AutoCAD DCL
definitions), to provide more flexibility, more comfort and
improved GUI appearance.
Using extra DCL attributes is compatible with
the DCL syntax (even Lisp + BRX applications can add any number of
custom attributes), therefore it is backward compatible with
AutoCAD, and does not harm - AutoCAD (and other DCL enabled
systems) will simply ignore such BricsCAD-specific
attributes.
these are BricsCAD specific DCL attributes
