bcad_label
BricsCAD uses a genuine multi-column control
for listboxes.
As a result it is possible to have
resizable columns and real column
labels.
The DCL engine tries to detect single-line
column labels in the label
attribute of legacy DCL code.
To specify single- or multi-line column
labels, the bcad_label
attribute can be used.
This attribute specifies the column labels of
a multi-column list_box; column labels are to be separated by tab
"\t".
Within the column label text, newlines "\n"
may appear to specify a multi-line column label.
The BricsCAD DCL engine can also detect column
labels from the label attribute.
If both the label and bcad_label attribute are
specified, bcad_label
will be used instead of label.
When using the bcad_label attribute, the
plain label attribute can be specified as an alternative on other
DCL engines.
Applies to : listboxes only, otherwise ignored
