bcad_width
If bcad_width it is specified, it
is used instead of the standard attribute width to set a
minimum width on
any tile.
This allows to bypass small cosmetic problems
in the BricsCAD DCL engine.
Since the BricsCAD DCL engine is implemented
with WxWidgets, some small visual differences with an MFC based DCL
engine cannot be avoided.
This is however rarely needed and normally
concerns details only.
Applies to : any
DCL tile can use bcad_width
