mech:parameters-set-geomdrivenmode
(mech:parameters-set-geomdrivenmode  parameter  mode)
Assigns a new geometry-driven mode (integer, Off=0, On=1, Auto=2) to the specified parameter (integer).
Arguments
parameter (integer) the parameter identifier to be modified
mode (integer 0...2) the new 'GeometryDriven' mode value for the parameter
Return
T if successful, or NIL otherwise
Example
(vl-load-mech)  2
(setq blkId (tblobjname "BLOCK" "*Model_Space"))  <Entity name: 4aaa68b0>
(setq param (mech:parameters-get-byname blkId "Length"))  971708080
(mech:parameters-set-geomdrivenmode param bc3dcGdOn)  T
Remarks
for the 'GeometryDriven' mode, see 3DC Parameters GeometryDriven Mode
Note
©  Bricsys NV. All rights reserved.
