mech:compdef-get-isupdated
(mech:compdef-get-isupdated
blkRefOrSolid)
Verifies whether the component, referenced by
the blkRefOrSolid (ename) entity, is up-to-date or not.
Arguments |
blkRefOrSolid (ename) the entity to query |
Return |
T if updated, or NIL if not updated, or not an external component (and in case of an error) |
Example |
(vl-load-mech)
1 |
Remarks |
blkRefOrSolid could be a BlockReference or 3dSolid |
Note |
this function applies when the referenced component definition is an external dwg file |
