param:constraint-set-directions
(param:constraint-set-directions
constraint mode)
Defines the direction mode (integer 0-3) for the
specified constraint
(integer).
Arguments |
constraint
(integer) the constraint to modify |
Return |
T on success or NIL on failure |
Example |
(vl-load-mech)
2 |
Remarks |
not all constraint types support all direction modes (or do not support direction mode at all) |
Note |
