param:constraint-set-isenabled
(param:constraint-set-isenabled
constraint T/NIL)
Defines whether the specified
constraint (integer) is enabled (T) or disabled (NIL).
Arguments |
constraint
(integer) the constraint to modify |
Return |
T on success or NIL on failure |
Example |
(vl-load-mech)
2 |
Remarks |
Note |
