param:constraint-set-name
(param:constraint-set-name constraint
name)
Assigns the new name (string) to the
specified constraint
(integer).
Arguments |
constraint
(integer) the constraint to modify |
Return |
T on success or NIL on failure |
Example |
(vl-load-mech)
2 |
Remarks |
Note |
