param:constraint-set-measurement
(param:constraint-set-measurement
constraint argIndex mode)
Defines the measurement mode (integer 0-2) for the
specified constraint
(integer) at the argument index
argIndex (integer,
0/1).
Arguments |
constraint
(integer) the constraint to modify |
Return |
T on success or NIL on failure |
Example |
(vl-load-mech)
2 |
Remarks |
not all constraint types support all measurement modes (or do not support measurement mode at all) |
Note |
